Forum > Ostatní > Jak naladit ovladac do BMW?
 o Navštíveno 2260x o
o 23.10.2009, 08:28 | toxic
Kdo poradi jak mam naladit dalkovej ovladac na otvirani garazovich vrat do BMW730? Frekvence je jedno. Ovladacu mam spoustu druhu,jen me zajima zpusob jak ho ulozit do auta.
o 23.10.2009, 08:41 | Pekys
spíš se zeptej na bmwklub.cz nebo koukni do návodu.
o 23.10.2009, 09:14 | toxic
Navod nenajdu a na BMW klubu zatim nikdo nevi
o 23.10.2009, 09:22 | Pavel 528
jako uplne nechapu dotaz,na co ho chces naladit?
mas nejaky dalkac ke dverim a chces to ovladat ovladacem jinym?jakoze dalkou k autu,nebo to nechapu...
o 23.10.2009, 09:25 | zipp
tipuju to tak, že v autě je nějakej origo ovladač na garážový vrata zabudovanej a on by ho chtěl nakódovat na svoje vrata, ne?
o 23.10.2009, 09:31 | Pekys
pochopil jsem to stejně jako zipp, ale nevím co všechno je v 7er za výmysly.
o 23.10.2009, 10:42 | .mycTD
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below.
NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
o 23.10.2009, 11:14 | toxic | Upraveno: 2009-10-23 11:19:10
To je vono. Potrebuju si naladit do auta dalkove do vestaveneho ovladani.
o 23.10.2009, 11:52 | fredy
jj myslím že ho máš ve zpětném zrcátku že :)
o 23.10.2009, 12:32 | KaZaN
Chci takýýýý (garáž, ovládání, zrcátko...) (o; Já musím jak dement stahovat vokýnko a přikládat kartu, very coooool, za ty prachy )o:
o 23.10.2009, 21:25 | free.tree
.. hustá funkce... o tom jsem nevěděl... :-O
o 23.10.2009, 22:19 | .mycTD
nechapu, proc to nemaji vsechny normalni auta, kdyz vyrobni naklady jsou jako na ovladac k TV
Stránka vygenerována za 0.4021 sekund.
