Forum > Ostatní > trubičkové sluchátkové zesilovače
 o Navštíveno 2150x o
o 12.12.2010, 18:06 | LukeFab | Upraveno: 2010-12-12 19:06:01
Budu si kupovat Sennheiser hd600 a nejspíš k nim budu potřebovat zesilovač.Našel jsem na ebay tyhle trubičkové zesilovače [ Link ] co si o tom myslíte?Poslouchat budu z pc ze zvukovky Asus Xonar D2X a z Ipod Touch
Specification:
In Put Power: DC24V
Input Sensitivity: 100mV
Input Impedance: 100KOhm
Out-Put Impedance: 20~600 Ohm
Gain: 30dB
Frequency response: 10Hz-60KHz +/- 0.25dB
Signal/Noise Ratio: >90dB
Dynamic range: 84.6dBA(300 ohm) 89.8dBA(33 ohm)
THD: 0.016%(300 ohm) 0.45%(33 ohm)
IMD + Noise: 0.045(300 ohm) 0.42(33ohm)
Dimension:79mm (D) X 79mm (W) X 44mm (H)not measure to tube and transformer
Shipping Weight: 600 g
a podobnej má tyto specifikace
Pure Class A Headphone Amplifier & Pre Amplifier
Hybrid ! Valve & MOS-FET in Use!!
Without any OP amp IC inside!!!
Audiophile Performance Design Absolutely!!!
Our Indeed headphone amplifier is different to others.
A/ High grade Caps & Dale resisters, ALPS volume in use.
B/ High cost Large 24V2A low noise adapter with grounding.
C/ Precision select 6922 valve, also match R/L channel within 1dB out put differential.
It is a high value and cute headphone amplifier hook up to your PC / Mp3 /MP4/ ipod / any stereo device. You can have a powerful, dynamic and sweet TUBE SOUND from your headphone ! You’ll be astounded at the improvement in sound quality, dynamic range, meticulous transparency, completely demonstrate its high performance and analytical ability, it can also connect with power amplifier such as a high performance pre amplifier to improve your Hi Fi system.
New electro-harmonix 6922EH tube made in Russia
(we have carefully choose and test in Lab).
-Using Elna Caps and Dale resistor.
The each one of 6DJ8/6N11/ECC88 is fully suitable for replacement with much difference musical taste chose by owner. (6DJ8/6N11/ECC88 Excluding in this item for sale)!
In Put Power: DC24V
Input Sensitivity: 50mV
Gain: 20dB
Signal/Noise Ratio: >91dB
Shipping Weight: 0.55 kg
o 13.12.2010, 08:04 | Milhauzz
Trubičkové :) ROFL hnedka po ránu ....
Je to jakýsi hybrid lampy a mosfetu. Kdo ví jak to hraje, ale když někdo něco zbastlí a k tomu napíše TUPBE SOUND tak si z toho rozhodně nesednu naprdel...
Nedávno sem se pozastavil nad jedním threadem na hifi slovanetu, kde borec vybíral repráky a vyloženě psal "po 4 hodinách surfováním internetu jsem se rozohdnl pro tyto ..." (imho kokot)
Takže moje rada zní, údaje na netu nehrajou, marketing nehraje, fotky nehrajou. Zvedni zadek a di do nějakýho hifi studia. Dneska jsou tyhle předzesilovače v sortimentu každýho lepšího kamennýho krámu.
o 13.12.2010, 08:17 | Pavel 528
o))))jako Milhauzz
presne tak ,papir resp.net snese vsechno...je to proste klasicka elektronka,ktera je jako predzesilovac a konec jsou stejne tranzistory..
nicmene nerikam,ze to bude hrat spatne....
ale diky tomu,ze je to prave jen pro sluchatka,tak vystupni vykon je nula,nula nic a tedy i zkresleni ktere uvadeji je sice skvele,ale v podstate normalni.....
no proste tu lampu tam dali protoze se diky tomu muze udelat o hooodne vyssi cena..tot vse...
tyto parametry by sly udelat s klasickym operakem za par korun...
o 13.12.2010, 12:37 | ruffrider
...a já si říkal co to je, "trubičkové" :-)
Nesmysl, snobárna?
viz Grado headamp - mahagonový špalek za 13 000
a uvnitř? operák + součástky dohromady za cca 50,- kč
šel bych do tohohle
foto k příspěvku  od ruffrider
o 13.12.2010, 12:38 | ruffrider
...a střívka zmiňovaného Grada
o 13.12.2010, 12:40 | Lukasino
To grado je pecka ovsem :o)))
Jak je to vyplneny drevem, aby to alespon neco vazilo :o))
o 13.12.2010, 12:42 | Pavel 528
hezky..no a ty kabliky,to je mazec,zadne stineni nic...no vylozene highend..o)))
o 13.12.2010, 12:46 | Dave0401
trubickove :DDDDD
... to je moc :DDDD
... a to provedeni nekterych zarizeni maras :DDDD
o 13.12.2010, 13:02 | Zdeny60 | Upraveno: 2010-12-13 14:02:37
LukeFab:
tube není jen trubka či roura, ale taky vakuová eketronka = po staru "lampa, flaška" :-)
Jinak HD600 si zaslouží opravdu něco lepšího, než to, co je tvém linku a to Grado se snad nedá ani komentovat. Resp., jeden komentář k tomu dám - závidím těm, co tohle dokáží prodat. Tomu se říká byznys!
Doporučuji to nasštuduj si stránky fimry casea, BV Audio, pročti si nabídky profi firem (Behringer, Alesis a další) a z toho vybírej. Za stejný peníz dostaneš opravdu něco, co bude aspoň trochu hrát...
A pokud nemáš nějak zvláštní důvod, proč zrovna lampy, tak se na ně vykašli... MosFety ti udělají stejnou služnu a nebudeš se muset o nic starat (náhradní lampy, jejich nastavení, párování a shánění a placení nemalých částek za lampy v dnešní době).
o 13.12.2010, 13:05 | Zdeny60
I když - podroběnji jsem si přečetl zadání - te´d můžu s klidem říct, že to Grado bude stačit. Ipodu a MP3 nepomůže nic... Na toto nepotřebuješ HD600, na to stačí Koss za 1000,-
o 13.12.2010, 13:08 | LukeFab | Upraveno: 2010-12-13 14:14:36
no ja nemám finance na to abych dal za zesik ke sluchátkům 13tkč,klidně bych koupil něco použitýho,já tomu nerozumím,tak jsem klasicky najel an ebay a koukal co existuje.cesky fora jsem taky prolezl. viděl jsem i borce co si ty zesiky sami postavili,ale nevim no.nechtěl bych za to dát víc jak 2t.
o 13.12.2010, 13:15 | Lukasino
No ja si taky rikal jako Zdeny, proc takovou techniku na ipod? :o))
o 13.12.2010, 13:20 | LukeFab
bude i lepší zdroj časem,jen nevim jakej ten zesik do 2t
o 13.12.2010, 13:33 | Lukasino
Neni skoda vzit sluchadla za sedmicku a povesit je na zesilovac za 2tis.? :( Urcite by si zaslouzili neco lepsiho...
o 13.12.2010, 13:39 | LukeFab
to je sice asi pravda,ale zatim nejsou finance,tak nekde musim začit ne?
o 13.12.2010, 13:45 | jasisoft
davnejsie bol pekny test sluchatkoveho zosilovaca, ktory som mimochodom mal tu cest pouzivat asi 2 tyzdne doma a osobne mozem doporucit. az na tu cenu...... [ Link ]
o 13.12.2010, 14:09 | All
Pokud jen zesík tak kup tohle než ti to někdo vyfoukne: [ Link ]
Tady je test: [ Link ]
Osobně bych ale spíš doporučil koupit levnější sluchátka a vyhnout se jakékoliv zvukovce. Tu tvoji neznám tak je to možná špatně. Pokud se ale zvukovce vyhneš dostaneš jen digitální signál. Kup D/A převodník s integrovaným sluchátkovým zesíkem (předzesilovačem) - [ Link ] . Sluchátka pak něco jako AKG K601, Beyerdynamic DT 660, 860 atd.
Stránka vygenerována za 0.3075 sekund.
