Forum > Vzkazy > 2 FBS
 o Navštíveno 107x o
o 02.10.2005, 17:52 | rossi.x
EXHAUST INSULATING WRAP
The original Exhaust Insulating Wrap was developed over 12 years ago by Thermo-Tec. Exhaust Insulating Wrap is an innovative way to create more horsepower and reduce under-hood temperatures.
Wrapping headers maintains hotter exhaust gases that exit the system faster through decreased density. Increased exhaust scavenging is produced, along with lower intake temperatures. Exhaust Insulating Wrap withstands continuous heat up to 2000°F, and contains no asbestos.
Thermo-Tec exhaust wrap will not over-insulate a system when properly installed due to a proprietary coating developed by Thermo-Tec - Thermal Conduction Technology (TCT) - that conducts heat across the wrap's surface. This coating controls heat build-up and dissipation.
o 19.09.2005, 18:29 | rossi.x
foto k příspěvku  od rossi.x
GENERATION II COPPER HEADER WRAP
Generation II Copper Header Wrap improves heat resistance up to 30% more than current technology, by utilizing a new proprietary coating developed by Thermo-Tec; improved Thermal-Conduction-Technology (T-C-T).
Generation II Copper Exhaust Wrap creates more horsepower and reduces under-hood temperatures, increases exhaust scavenging, withstands continuous heat up to 2000ºF, contains no asbestos.
Generation II Copper Exhaust Wrap is sold in one or two inch wide, 50 foot rolls with a low profile 1/16" thickness.
o 19.09.2005, 18:30 | FBS
kolik to vůbec stojí?
o 19.09.2005, 18:30 | rossi.x
o 19.09.2005, 18:30 | kral007 (eXtrem-audio.cz) (M)
2,5cm sire a tusim 10m delka tusim 1600
o 19.09.2005, 18:31 | rossi.x
tak hochu, to netuším.
o 19.09.2005, 18:32 | rossi.x
to kral007: kdo to tady dealuje?????
o 19.09.2005, 18:34 | kral007 (eXtrem-audio.cz) (M)
lexani racing, C.A.T.
o 19.09.2005, 18:36 | kral007 (eXtrem-audio.cz) (M)
dela se sire 2,5cm a 5cm a v delkach 5m a 10m
nedavno jsem to kupoval
takhle to vypada v realu
o 19.09.2005, 18:39 | rossi.x
pěkný, a co na to voda a bordel?
o 19.09.2005, 18:41 | kral007 (eXtrem-audio.cz) (M)
ono je to tak pevny ze to asi nevadi, ja to od doby omotani nevidel, bylo to na zakaznickym aute :-)
o 19.09.2005, 18:42 | rossi.x
aha, a nedělali jste někomu celý svody? co na to měření na brzdě?
o 19.09.2005, 18:44 | kral007 (eXtrem-audio.cz) (M)
delali se na te RX8, komplet svody az po stredni dil
o 19.09.2005, 18:47 | rossi.x
no a funguje to? naměřili jste víc HP?
o 19.09.2005, 18:59 | kral007 (eXtrem-audio.cz) (M)
hlavne se namerilo pri prvnim mereni mene koni bez jakych koliv zasahu nez pise vyrobce
ted tam je sani Greddy, vyfuk HKS, turbokitGreddy a prijdou jeste odlehcene remenice, po vymene remenic se to bude merit dal. melo by tam byt cca 300koni
o 19.09.2005, 19:02 | rossi.x
tak to už je slušná pohonná jednotka:-), dík za info
o 19.09.2005, 19:06 | erix7 (K)
Lukasi pckej, tak turbo a svody ? to mne nejde do kotrby. kdyz tak Turbo a down pipe, headers pri NA - pokud kecam opravte mne .
o 19.09.2005, 19:15 | kral007 (eXtrem-audio.cz) (M)
je to NA s dodelanym turbem
o 19.09.2005, 19:27 | Daryl (A)
rossi: nejak se ti sere net. Posilas vetsi fotky, nez tve pripojeni zvladne. Tady se davaj fotky kolem 600 na sirku, tak je zbytecny sem posilat mega fotky 2000 na sirku a podobne ... zas to neprehanej.
o 19.09.2005, 19:30 | rossi.x
sorry, tak jak to má bejt velký?
o 19.09.2005, 19:53 | rossi.x
tak nic:-( nevim, no:-(
o 19.09.2005, 19:54 | rossi.x
o 19.09.2005, 20:05 | rossi.x
sice nevim kde se to tam vzalo :-))) ale takhle nějak asi vypadaj svody na turbu. :-)))
Stránka vygenerována za 0.4305 sekund.
