Navštíveno 189x
mam ted Hertz HSK
a nic moc uz jsou utrzene a to na -2db :-(
06.08.2007, 19:29 |
erix7 (K)
si porid XXX RE kompa voe :)
ne ted vazne odporucim ti ProX T2
[ Link ] a domecek na ne
A nechces Radical Audio? Jsou ze setu kde je jeden odpaleny stredobas...
jako Erik, U-Dim ProX T2 tě nezklamou..
a ty radicaly maji jake parametry??
a kolik za ne chces??
a z nebo bez vyhybek??
TWEETER MODEL RA20.2T
Nominal Diameter 20 mm
Nominal Impedance 4 Ohms
Frequency Response 1.9kHz - 22kHz
Resonance Frequency 1.9kHz
Sensitivity 90dB
Continuous Power Handling 150 Watts*
Mounting Diameter See drawings page 21
Mounting Depth See drawings page 21
*Via 18dB/oct. highpass filter network @ 4kHz
C 20MM STRUCTURE REINFORCED AL-DOME TWEETER
C ULTRA-COMPACT HOUSING & MOUNTING ADAPTERS
C NdFeB NEO-MAGNET DRIVE
C PU-RUBBER SURROUND
C KAPTON™ VOICE COIL FORMER
C FERROFLUID COOLING
C FLAT SURFACE AND FLUSH MOUNTING OPTION
C FLUSH MOUNTED TWEETER CAN BE SWIVELED
Predstavu o cene moc nemam. I s vyhybkama do 2 tisic, zalezi na dohode.
07.08.2007, 10:41 |
Ricci Aj tieto vysky nieco vydrzia :-)
